I’m looking to get a Suttner gun soon but all these model numbers have me confused. Some have different numbers and identical stats. I have a 4200/4.0gpm machine for concrete and soft washing houses using an Xjet M5, any suggestions?
Suttner 2315 is one of the best guns. Nice trigger and chemical resistant.
If you plan on sticking with Xjet you can skip the more costly ST-2315 and run the ST-1500 since your gun won’t see any chem. If you DS SH then go with the ST-2315
Just purchased a 2305 and a 2315. Man they’re big even with my big hands.
What ever gun any one buys, make sure it is at least 12 gpm.
Ditto.
When you finally give up on the xjet and switch to downstreaming, you’ll have a nice gun that’ll hold up to some abuse.
If you squeeze the trigger slowly on these guns, you can negate the kick that’s inherent in pressure-actuated unloaders. That goes for all of Suttner’s “easy pull” guns, as I understand it.
M m.nm. mb
.m.m. n
