Whats your pressure at the handle for your surface cleaner. Please include your GPM and PSI… Also what tips are you using. Do you have a 2 bar or a 3 bar system
Im running 5.6 gpm at 3000 psi and a 3 bar 18" surface cleaner running 25 degree spraying system nozzles. It works that fastest for me and cleans great.
5 gpm 3000psi 2 bar 18 inch surface cleaner.
Sent from my SGH-T999 using Tapatalk 2
Running 28" surface cleaner @ 2700 psi 8gpm. Single bar 4 nozzles.
