Surface cleaner nozzle sizes
What size nozzles should I use for my surface cleaner? This would be for a pressure washer that runs 5.5 GPM at 3000 PSI.
I Know there are 2.5 gpm and 3 gpm nozzles, but there is no soft spot, 2.75 gpm nozzles. What should I use?
When I was using a 5.5GPM I went with 3.5 orifice to get 2500 psi… residential doesn’t need any more then that.
https://www.amazingmachinery.com/nozzle-calc.html
