Surface cleaner nozzle bar broke... should i upgrade to a 4 nozzle?
Sorry, i haven’t had time to do any research on this subject, but it just broke, and i need to order it today… so i might be asking a question that has already been answered.
It is a mosmatic 21" surface cleaner… and i think it uses the 19" bar. Has 2 nozzles. Should i upgrade to the 4 nozzle bar?
My machine is a 4GPM 4200 PSI direct drive ( I know that the 19" is not the proper size for a 4 GPM machine, but it’s what came with it when we got it).
Also, i briefly looked online, and it looks like Southside sells a 4 nozzle where it’s just 1 bar with 2 nozzles on each end, and powerwash store sells one where it is 4 bars. One better than the other? I didn’t see any at Pressure Tek.
Thanks for any advice!
You HAVE TO HAVE A 8gpm washer before the 4 nozzles does any good…
Look down for 4 nozzles tips talks all about it…
It will work but the nozzles will be so small they will clog up constantly
Ok cool, ill just replace it with what was on it. Thanks guys.
