Can anyone tell me what this pink blockage that keep coming popping up on my BRAND NEW Simpson Surface Cleaner I JUST got in the mail 2hrs ago? I clear it with a little pin and squeeze the trigger and it seems to be just fine, but everytime I start up the machine, the pink blockage pops up again
Take the tips out and run some water through it.
Those crappy surface cleaners come equipped with 0 degree nozzles… Clean it off, return it, and buy a better one for around the same cost. You’ll be happy you did.
Lowe’s Home Depot and some of the big box stores use a red thread sealing compound for the pressure washing equipment…maybe they used it too!!..I’m with @dcbrock take the tips out run the washer and blast the junk out…then put the tips back in and try it!
This one is around the same price and will work a lot better for you.
https://www.amazon.com/BE-Pressure-85-403-014-14-inch-Surface/dp/B07F3T6YWQ
Lol @anon37135677 it might be a crappy surface washer but we all had to start somewhere.
Lol how do you think I know that it comes with 0 degree nozzles… that’s why I showed him the BE one. It’s around the same price and will most likely help prevent any damage he may not see coming.
