Hello from Czech Republic. I´m looking for a suitable surface cleaner for my preassure washer. I have preassure washer POWXG9100 here are the parametres…
|Cylinder volume: 210 cc|
|Max. pressure: 270 bar|
|Maximal water flow: 540 l/hour
|Hose length: 20 m|
|Hose length: 20 m|
|Rated pressure: 170 bar
Here is the link for the preassure washer - https://www.varo.com/p/powxg9100/high-pressure-cleaner-210cc
I would like to know what would be the most fitting surface cleaner for this kind of preassure washer ?
Any information will be a big help.
Thank you very much.
Any chance you can convert to Imperial measurements?
Best I can tell you have a homeowner grade 2.3gpm machine. This forum is mainly for commercial pressure washing equipment and techniques.
Thank for the message.
Normal working PSI is - 2500
Max PSI Is - 4000
2,3 gpm
I know you guys here deal with proffesional stuff for thousands of dollars but as a newbie I would really appreciate any piece of advice.
What do you think would be the best surface cleaner for this rate?
I started with a similar machine but didn’t use a surface cleaner until I got a 4gpm. I don’t know what you have available in your area.
