If I were softwashing a roof - is there any reason why I shouldn’t capture the mix and pump it back onto the rest of the roof instead of using a large tank?
You’d have a filter before it was directed back to your container. The quantity always starts with what you have in the tank so a filling valve would not be needed.
In addition to reacting with organics, you also have the issue of the chlorine evaporating out very quickly on a hot roof. What you collect from the gutter downspouts will be a lot weaker than what you sprayed up on the roof.
There’s no way I’d run the sludge that comes out of the gutters I’ve bagged back through my expensive pump/hoses/reel. No way. @MuscleMyHustle is right, if you’re priced correctly then the client already paid for the chemicals
Yes, this thread is accurate. Let’s say you did collect the runoff, which shouldn’t be much anyway. What you would be collecting has already lost much of the SH to contact with mold/mildew/slime on roofs. If there wasn’t some kind of gunk up there, why would that have called to get it washed?
Organic contaminates and heat would make the SH no longer very effective. I don’t see the point in collecting it to try to use again. The whole runoff probably doesn’t cost more than $10 to make and it would be more than $10 worth of frustration to collect that amount to reuse.
I’ve been using slo-mo and on roofs that are very steep or ones with lots of sensitive plants/stained wood or other risky factors I will double up on the amount so it barely runs down, especially tile roofs where it runs quick down the slide between them.
