Possibly. I will have to see what’s bypassing when on the trigger again. It wasn’t much.
One more thing, with 5.5 will i need a buffer tank or should i be safe on the spigots still? i know most homes should be at 7gpm from the spigot if i recall correctly
Not sure about most homes being 7 gpm at the spigot. I believe it is closer to 4-5 gpm. Sure you might have a home here or there with higher flow. I run 8 gpm and have to watch my buffer tank on residential as most homes I will outrun the water from the house.
Absolutely zero sense bolting on another direct drive pump when the blown one will be off the motor. invest in a belt or geardriven setup. Direct drives aren’t built for what we do, order 2 and keep one on the shelf.
Every area is different but you should run a buffer on anything over 4 gpm. I had a 4 gpm to start the summer. I had two houses where I had water issues. Starving the pump like that can ruin the pump.
65 gallon buffer should be plenty for a 5.5.
Home water in my area produces anywhere from around 2 1/2 gallons to 5 gallons. Most are around 4. Just depends on the area
Was wondering the same thing.
He probably wanted to weed out all the bad advice that would flow in.
i wish i could but at the moment i just don’t have the money for it i need to get something quick so i can get back to working
Just FYI- I was doing some spray painting with my Graco sprayer today. Needed to prime pump with some water before starting. Had a 1 gal pail. Took 14 seconds to fill it. Newer sub-division on city water. That is just a tad over 4 gpm.
Word of advice - anything over 4 gpm, have a buffer tank. Even it is only 25 gal tank, you will need it.
should i buy a ZK1 unloader or does the pump you linked come with one by chance? i put in my order last night for the pump. hoping everything gets smoother from here, been a real rough week with my car phone and washer breaking
Have to buy one. Sorry about your week!
All good. looks like i can pick up the ZK1 for 100 with shipping. On the bright side i’ll come out of this with much better equipment than before. everyone has hardships at some point.
also do you know where the best place to buy a gx630 is? Northern tool has a handful but i don’t know the differences are. https://m.northerntool.com/shop/tools/category_honda-engines?newSWTerm=688cc&Search.x=0&Search.y=0
I bought a GX690 from sprayer depot. It was $50 more than a 630 I think.
that’s exactly what i was looking for. thanks man
Welcome. Call them as they don’t sell it on the website. Brandon the GM can help. https://www.sprayerdepot.com/ I got my Honda GX690, udor gearbox, udor CKC 30/24 pump 8GPM @ 3500PSI mounted to a skid with an OEM Honda muffler (most have generic knock offs to save money) for $3150. Shipping will add some depending on where you are.
Hey do you still have a link to those oil drain hoses you have? I just swapped oil today and it went everywhere
Depends on what size you need but yes.
GX390 RuggedMade 12mm Oil Changing Engine Drain Port Hose https://www.amazon.com/dp/B000PDN6R6/ref=cm_sw_r_cp_api_fabt1_gbXVFbD6D6WP6
GX690 RuggedMade 20mm Oil Changing Drain Port Hose for Honda V-Twin Engine https://www.amazon.com/dp/B07RRKCM67/ref=cm_sw_r_cp_api_fabt1_TbXVFb426A6AH
