As some of you may know, i’m running some low tier 4/4400 machine as i‘m still getting my foot in the door of the business. It’s a simpson 4400/4gpm turd box. Yesterday on a house wash my pump practically blew up, its got a hole on the bottom that leaked all the oil out. I’m looking to get a new 4gpm since it’s all my 13hp motor can push out. I know the best pumps for 8gpm are udor pumps, maybe general too. But for these weaker 4gpm pumps my options seem to be AR/GP. Is there any brand in particular that reins supreme for these lower flow pumps? I’ve been suggested by a few people to buy this AR pump i’ll link below
Here’s the link im about to pull the trigger on so i can get back to work asap
I’ve heard bad things about built in unloaders off my memory idk if this is classified as a built in. Is this a waste of money? Can i plumb a buffer tank to it or do i need a belt drive? or is belt drive only needed if you’re running exclusively off the buffer/reservoir supply?
The GPMxPSI/1100 says 4gpm is the highest i can go with a decent amount of pressure for flatwork. But i do see some people going over that limit. Would a 5/3500 be possible with 13hp or should i just stick to 4/4000? 4k is way more than i’ll ever need but it seems to be the only option for the pumps i’m seeing at 4gpm
I run a 5.5GPM 3800PSI Allison pump with gearbox from Envirospec on my GX390. I have it set to 2500PSI which is what the GX390 can provide with 5.5GPM. $579 price. Includes the gearbox, takes 4 bolts to attach which it comes with.
So you reckon I can get that with my current 420cc 13hp engine, maybe get 2800-3000 psi out of it? Most of my work is flatwork like driveways patios etc so the extra psi does help. It’s out of my budget right now since I just had to pay for insurance and school the other day, although I was in the middle of a $385 job that once completed could let me buy that pump. I might have to rent a 4gpm from home depot and finish the house wash with my X-jet. Shouldn’t be a problem i believe
The pump you linked says 6.3 gpm. is that correct? I’m gonna go ahead and rent a washer to finish this job so i can purchase the better pump you linked. Im skeptical if my motor is even 420cc… got the whole thing with 4gpm pump for $800 which sounds too cheap considering the gx390 alone is around that if not more.
Predator makes 420cc motors. The website has a text error. The previous page shows 5.6GPM when you click it lists the bigger one. You can call and order as well.
