I need a pretty strong mix I think BC the stucco is green and cracking so I m going to have to use my ball valve for the job
I use my roof system for stucco snd dryvit.
What about a mix
SH and elemonator is what I use. Miix some up and test an area until you get the right mix for your application
Just be careful putting pressure on it. It’s just layered styrofoam so you don’t wanna dent it. I tried a low pressure strong DS mix out of our pressure washer on the first dryvit job I ever did and it wouldn’t touch it. Had to do a strong mix from our roof pump to get it clean.
I’m glad I came across this thread, I have a 7,000 Sq ft house on Monday, all stucco, lol. But that’s what’s I suspected. That I’d have to use a strong mix thru my roof pump. How strong did you have to go to get results @anon1966941?
Man I can’t remember. I just kept making it a little stouter and testing it until I hit that sweet spot.
@Masterblaster57, if the stucco is cracking, get some before pictures.
Then they can not say you cracked their wall.
Good call bill didn’t even think about that I’m going to be a pro camera man before I start lol
Yes indeed! I get before pics of every splintered board, cracked stucco, faded vinyl, faded paint, etc.
I found the sweet spot on that large stucco house I did the other day. Just slightly less than my roof mix, which is 40%, took care of all the bad green and black spots, then watered it back down to a more normal house wash mix for the rest. Worked great!
