Best way/ product to use to remove these stains. Cannot use sirface cleaner and havent had luck with EBC (maybe using it wrong?)
So how did you use it? Why can you not use a surface cleaner? You have heat?
No heat, neighboring units with things in them, and followed instructions on back and no luck
use gold assassin, for sure you’ll get results, not sure how good but I’ve yet to find ebc works for me with cold water.
I don’t see how you can’t use a surface cleaner but you will rinse it with a hose? Won’t the water get in those places with a hose? I’d be using socks at every door and have a guy with a squeegee on standby so someone doesn’t hit the contractor lottery.
