My question is I have a 4gpm 3500 psi landa belt drive cold water unit. I was wondering if that can work on fleet and what would I need to apply 2step to the equipment
Gator wash LLC
Gator wash LLC
4gpm will work you can wash a truck with a hose. But time is money 4gpm is slow but can work. I don’t recommend you use acid until you understand how to apply it. Lol
Chemicals can be applied with different injectors. Up stream or down stream.
I was looking into the two-step hydro chem system
Gator wash LLC
Differnt strokes for different blo
Far as what
Gator wash LLC
Typo: I mean different strokes for different blokes. They all work some better then others in different situations. I’ve never used there remote injection setup but like any setup there’s positives and negatives. like all of us need to read and research and most of all put hours on the wand trying different Setup’s.
But for a non opinionated info remember and keep in mind that any hi-pressure down stream injectors cut pressure by 30% to create a chemical draw.
Yea I a two machines set up 4gpm for chemical and 8gpm rinse
Gator wash LLC
