Let’s hear from all the Black Belts in Power Washing - FYI I’m running 18 in titan electric reels and doubling two g390 Simpson for 8GPM output to optional Hot water…
MORE PHOTOS TO COME OVER THE NEXT FEW WEEKS
Yep, you definitely want a tandem axle if you’re using an IBC tote as your buffer tank. Good idea for any trailer setup, really.
Most guys here will recommend having one 8gpm machine vs two 4gpm’s. But you work with what ya got, right?
In any case, keep in mind orientation and spacing of:
If I were doing a rig as small as yours, I would strongly consider eliminating the chem tank and just having one rectangular SH tank, under 100 gals
Yeah it will be tight but I purchased a 5x10 with capable towing capacity. It was one of highest rated in the United States.
What website or software is that? Trying to build my trailer here soon but need to map out equipment
