[SIZE=3][COLOR=#000000][FONT=Calibri]4gpm/4000psi must be a regular power washer. You mentioned running soap through your pump,if it’s a pressure washer stop doing that, it’s not necessary and not too good for the pump. Here’s how you softwash with a pressure washer. [/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]1. You have a water supply to the pump. [/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]2. The pump takes that water and pushes it out the outlet side at a static pressure amount, you should not change this by messing with the unloader. This goes to your pressure hose, you can have a reel there too it doesn’t matter.[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]3. After the unloader you add a downstream injector. Water passing through the hose and through the injector creates a venturi and sucks the soap through the tube from your separate container of soap and adds it to the water in the pressure hose. This happens after the pump so only fresh water goes through the pump.[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]4. How much pressure comes out at the end of the hose depends on the tip you put at the end of your gun or wand. Different size tips (by diameter) being larger or smaller, allow more or less water out the end . Larger (diameter) tips allow more water out so the pressure drops, smaller (diameter) tips restrict the flow creating more pressure. The degree of the tip only controls the spray pattern not the pressure, a zero degree tip gives you a tight pattern almost like a straight line, while something like a 25 degree tip give a wide fan. In order for the venturi to work, lower pressure is required, so a large (diameter) tip is necessary.[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]You have a few choices of when you draw soap.[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]A. Wide diameter tip lowers pressure enough for the venturi and you draw soap, change to a smaller diameter and you stop drawing soap, this is done with a quick connect at the end of your gun or wand.[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]B. Just pull the tube out of your dedicated soap bucket, nothing to draw from anymore so just water comes out.[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]C. There are dual wands with a throttle grip that raises and lowers pressure at the wand. [/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]This is just the basics there are variables like hose length, etc.[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]Finally, don’t get confused, soft washing has nothing to do with the pump, it refers to the amount of pressure hitting the surface you are cleaning.[/FONT][/COLOR][/SIZE]
