Soft washing temperatures
Tomorrow i will be soft washing a house in new york, but the temperature will be around 50 degrees. Any one think that is still too cold
I washed today in 45 degree weather with no issues.
Just spike your mix a little stronger with a little longer dwell time.
Good to go.
Thanks brother
36 yesterday when I worked. You should be fine. If there is a lot of mold you can up your mix a little, and or use warmer water if you have that option.
Sent from my iPad using Tapatalk HD
