Soft washing Concrete
Sorry @SurfaceMedic ill stop lol
Uploading: 20190716_091744.jpg… Uploading: 20190501_122721.jpg… Uploading: 20190701_120512.jpg… Uploading: 20190501_152327.jpg… Uploading: 20190716_105839.jpg… Uploading: 20190701_102953.jpg…
Pics no workee,must try again ,grasshopper
I have tried 4 times I even tried to send grizz a message one by one will not load I got a big drive way to do next week I will try to upload video. But that’s how I was taught to do it I rarely use surface cleaner.
this is soft washed with a 20 minute dwell garden hose rinse. Obviously don’t care if I burn the grass …
I’ve never heard of any such product. Sounds interesting. Yes, I use SH on concrete. Pre and post treat with SH and either surface cleaner or wand at the least. Just never done a total ā€œsoftwashā€ on concrete or brick with no pressure at all.
So your spraying straight 12.5% with your 12v with your catalyst added? Why would you need anything to make your mix hotter if your spraying straight 12.5%?
I use a pump up sprayer with low splash bleach on brick near the bottom and xjet it on the bad areas like chimeneys. It creates a dense foam and removes it without having to rinse. I rinse anyways though.
I dont care about making it hotter the neutralizing part is what I’m after.
Why does everything turn into a complicated chemistry class??
Just hit the freaking concrete with a surface cleaner and call it the day.
Jeez…
I cant say no pressure but it’s real light with the steam.
Or you can use a chemical and it not take all day. Do what works for you just my 2 cents
Obviously you didn’t see my original post. Although I appreciate your response, I’m trying to avoid a surface cleaner on this particular job. Hence why I asked my original question.
Thanks for all the info. I appreciate the info you have passed along. We each do things a little different and that’s the reason for this forum, to learn from one another. So thanks.
I did read the post and I saw the pics. I have cleaned those type of bricks many, many times in my area. Obviously you dont blast them with 3000 psi and a surface cleaner. But the proper pre treatment and psi with a surface cleaner is the sweet spot.
You are correct. Obviously I’m not blasting away at anything with 3000 psi. I’ve cleaned these many, many times as well. However, I am trying to somewhat appease my clients requests if I’m able, and why I asked my original question. If I can charge accordingly and appease my client, it’s a win win for both of us. I’m not afraid of trying something new if I can use it to benefit myself while trying to please a client and that’s why I asked my question. So no offense, but wasn’t really looking for ā€œjust hit it with a surface cleanerā€ as that has nothing to do with my original question.
@Firefighter4hire your cleaning method is interesting but I can’t imagine it being cost effective spraying straight SH($$) and some other chemical($$) all over. Maybe on some small jobs but on some big jobs such as parking lots or some large res driveways. It sounds expensive and time consuming. And risky for burning grass or whatever else with over spray. 4hrs is plenty enough time to kill anything. Looking forward to this video. It maybe applicable to some future jobs such as the one @SurfaceMedic is looking at in this thread.
It’s also highly illegal in most areas if he doesn’t capture runoff and let’s it run down the curb into a storm drain. Major fines if you get caught doing that.
Dont have any run off and I apply the edges with a brush. I have never killed any grass. I dont know what you pay for s/h but I get 220 gallons delivered every Tuesday for 400 bucks. Plus it not illegal if it is neutralized
Ok. I’ll bite. Not trying to pick a fight or anything, incase it comes across that way. You said you do rinse, yet have no runoff. Makes no sense to me, but I haven’t watched your process either. Also, it doesn’t matter whether a chemical is ā€œneutralizedā€ or not, it is typically illegal to let any chems go down a storm drain. In most cases, even ā€œeco friendlyā€ and ā€œbiodegradableā€ soaps are not legal to let go into streets and drains. If you haven’t already, get very familiar with your state/county pressure washing bmp’s. All it takes is one call to the water dept from a disgruntled or environmental nut type neighbor, and you’re looking at fines out the nose and jail time. I believe @MrSparkleVA had that same scenario happen to him once. Brown stuff is typically sodium hydroxide. Not good to go down a drain either. As far as cost, I pay $1.65/gal for sh, but I pay absolutely nothing for homeowners water. In your 20 minute dwell time, me and my tech can wash and rinse a 2,000 sq’ driveway and move on to the next. Again, not looking for a brawl, just confused about your method, and would hate to see someone paying fines or doing time because a vendor told them a chemical was ā€œbiodegradableā€ and safe, but didn’t disclose what was actually in it.
