I have the same system as @SurfaceMedic. I use apple wash unless I’m doing roofs then I use cherry snotmenade. it depends on what I’m washing as to what I have the soap set on
I’ve heard it’s good. I try not to do too many roofs if I can help it. snotmenade seems to be a good all around soap. I’ve used it in lieu of elemonator and it did well. once I use up the elemonator I have I’ll probably just use cherry snotmenade for downstreaming and roofs. I like apple wash for stucco and f9 double eagle and ebc for a degreaser. other than f9 barc that’s pretty much all I use
I don’t dilute. Just dial it up or down depending on what I’m cleaning. I have a 5 gallon soap tank and I haven’t added to it in forever and get good soap when using. It doesnt use much with the metering system.
What used less bleach? Apple wash or your metering system?
I’ve been post treating by force feeding my ds injector with a 1gpm 12v. It’s so much faster not having to drag around both hoses. Right now it’s hooked up to a toggle switch but I plan on setting it up remote eventually. I know it won’t last forever but it’s like $30.
