Soft wash hose?
Just got my gas pump to supplement the 12 volt. Had been using 1/2" red kuritec hose and had no issues with it. Will run 5/8 for the new pump. Where did you buy your gas pump hose, which one are you using, and what is the minimun psi hose rating you suggest?
I use a 5/8" Red Kuritec from PWP. Higher than what your machine puts out.
