Is there an advantage to using one over the other to remove stain?
Big box stripper is just hydroxide or potash with a fancy name and price tag. 50 pound bag of potash cost $120 and will strip about 75 decks.
If your local vendor can’t get it for you try this.
Where do you buy it at that price?
Thanks man. What’s a typical mix for this stuff?
Six 12ounce coffee cups of flakes in a five gallon pail for downstream. 4 for xjet. Results may vary. Experiment. Be careful.
That was my next question, lol. What precautions do I need to take?
And is it effective if applied thru a pump up sprayer?
Read up on it. It will burn you. Can’t think of a reason to pump spray if you have a pressure washer. Maybe for treating oil stains?
Buy a truck load of old pallets and tinker
I actually have some old pallets. Good call!
What would you recommend the for cleaning grease on concrete and downstreaming it in on? Still 6 coffee cups?
I wouldn’t clean concrete with grease. Much easier work out there. You’ll just have to experiment
Ok thanks. I do some driveways with a cold water machine and customers often ask about oil spots…
Just tell them it won’t come up.
Did you mean 6 12 oz which is from what I understand 72 oz per 5 gallons
Or did you mean…
6 to 12 oz per 5 gallons…
Not being a smart ■■■just trying to figure out…
72 ounces per five gallons
Thank you.
