Simple Green Concrete and Driveway Cleaner
Does anyone here have experience using Simple Greens Concrete and Driveway Cleaner? If so what are your thoughts on it and, do you recommend it?
Just use bleach
I use a downstream injector so bleach should be fine but I tend to stay on the safe side so Im a bit hesitant of running bleach through it. Do you downstream it or run it through a chemical sprayer thats mixed with water?
I have a gas pump for bleach application. But in your case downstreaming is the way to go. Just carry a few extras on the truck an consider it a disposable item.
Bleach is the best for organics. I like Purple Power degreaser, but I’ve used regular Simple Green and it works good. Simple Green is concentrated and works well after downstreaming. Somewhere in the archives here there is a thread with links to a pretty good degreaser test.
