Did a little flat work for one of our landscaping customers. The customer came out to chat a little. Great guy who used to do all this type of stuff around his home - he’s just getting a little older these days but he knows a thing or two. He was convinced that the sidewalk was not going to get much cleaner and wished me good luck lol.
Hold up, they’re are about 15 different types and about a dozen of them suck. I use them every day but unless you are popping him or cleaning concrete stairs you probably didn’t need one. The won’t leave stripes with a wand because you shouldn’t be cleaning sidewalks with a wand
I use the same ones IBS mentioned and they’re probably the best I’ve ever used. I’ve rebuilt hundreds of turbos over the years and these are the only ones that I haven’t had to rebuild yet. Granted, I don’t use them often anymore but still.
I use my turbo for stair egdes and faces (risers) that the surface cleaner won’t get. I use turbos for retaining walls, but I get more use lately prepping basement walls for repainting. Those paint flakes go everywhere, it is dirty work, but I am a dirtyboy.
I use the PA turbos, reds mainly (I believe they are general pump, I don’t remember). IBS gave me the numbers so I could reorder them again (they went way up in price). I bought a blue but haven’t used it yet. You can clean a sidewalk really quickly with a turbo, probably faster than my SC, if you get the shuffle step right. I only use it on sidewalks around bilco doors or cracked broken areas.
Had to go out and buy one a month or so ago because it was the best non-chem method recommended by the manufacturer to strip some over-application of concrete sealer…only thing we ever used one for.
