Siamese kit
Does anyone have a picture of a Siamese kit installed on their pressure washer I need help installing thanks
Sent from my SPH-L710 using Pressure Washing Resource mobile app
Here’s the diagram. Need any help, let me know.
What is that used for?
Hook two machines together to double your GPM. (Cleaning/rinsing power)
Got it Russ thanks
Hi Russ. Do you feel that are safe for the machines and operator? Any potential hazards you’re aware of?
Following
I just bought two 4gpm pumps from russ and waiting on my kit + plumbing. I got the pumps because they can draw from a tank and I will plumb them together once in a great while for fun or if I wanna do a driveway or something sometime. I am running two 4gpm 4kpsi machines with two guys soaping and rinsing each half of the house. If you are planning on using this as your main setup at least get two kits from russ. You will eventually get points of failure.
Pump AR RKV4G40
You need a pressure trapped unloader.
I will keep all this ready in mind, for when to replace the pumps upon failure. Please send Russ website and contact info. I’m thinking of putting 5.5 gpm pumps on each of the gx390’s when the times come to swap out. Something about the way these Honda gx390’s and I assume gx690(will) purr through the years has me sold.
