Pressure Washer specs:
8GPM
3500PSI
Hose:
200FT
4700PSI
Two wire
Would this hose be okay, or should I purchase a hose with lower PSI?
8GPM
3500PSI
Hose:
200FT
4700PSI
Two wire
That hose is fine. You want your hose rated at least or close to the output of pw. Can go over all you want. Two wire is heavier however but more durable.
Be like buying new tires for your truck cause the current ones are rates for 100 mph but you only drive 60mph. Hoses are rates for a MAX psi.
Like racer said, two wire is heavy. I use a shorter two wire from machine that tends to drag across concrete.
