Short gun that sprays like a powerful water hose?
Where do I get the really short spray gun that sprays like a really powerful water hose?? I’ve seen a couple of others using them and don’t know where to purchase this. Please help.
Like this?
it’s just a normal trigger gun with a quick release fitting… instead of a screw on fitting for a wand.
What are you using it for? Do you have a pressure washer?
The key to getting lower pressure, and high volume from a pressure washer, is to use larger orifice spray tips. If you’re going for height/distance, one of the sniper/shooter nozzles is what you want. For lower work you want fan tips.
Yes I have a pressure washer.
