Short 4 stage telescoping pressure washing pole
hey guys,
im new to the forum and i was wondering if anyone knows which telescoping pole this is. i found the photo on amazon but it is for the harness not the pole. i contacted the seller but to no avail. i have a 5 stage 24ft pole and it is a beast. ive seen alot of other options but most are at least 6ft to begin with. this looks like the size of the standard wand with telescoping. any ideas? let me know!
Thanks in advance!
jim jones
41iW0COj33L.AC
Whole lot of nope, save your money and your back. Seems like a great idea…its not.
Ditto to what he :point_up: said , Save yourself pain and $
What are you using it for?
Suttner makes a telescoping pole, that’s all I know. Page 269 here: http://dcs.rm-suttner.com/Katalog/katalog-uk.pdf
If you want a compact extension lance that is in any way usable, I would probably DIY one with a carbon fiber mini waterfed pole, a straight trigger gun clamped to the base of the pole, some 1/4” pressure hose to go inside the pole, and jerryrig a spray nozzle to the top of the pole.
It won’t be cheap, but it’ll be usable.
https://windowcleaner.com/xero-micro-3k-high-mod-carbon-fiber-pole
Ive got the short version. Its the 1st gen powercare.
Best question…what are you using it for? If for washing houses forget about it. Get a good machine/equipment, use the right mix and technique.
I tried using it and it was horrible. You would have to be used to something like that, and i haven’t found a use for it yet. I had the idea that I didnt want.to use chemicals so I bought it, that would be its only use is to actually incorporate pressure.
They used these back in the day before ‘softwashing’ was invented.
It’s an alternative if you’re washing tile roofs, for example. Instead of having to get up on the roof, you can use a big stick off the ground. Nice.
You definitely don’t want to use that kind of pole to clean tile roofs, unless you like physical therapy ;>)
IDK, haven’t done it, but there’s a few channels on youtube who’ve used it. Blast Away, I think.
