I’m not busting your chops, but you need to have a better understanding of what you are throwing in tanks. It’s been raining with the occasional snow for 5 days straight here and I am bored and can’t do any work.
Here is the SDS for the product.
https://www.rustoleum.com/product-catalog/consumer-brands/jomax/jomax-house-cleaner-and-mildew-killer
IF you mix bleach, water, and a surfactant (soap), it will clean everything that this product is saying it will clean.
So, as I am not a chemist, and I am not tagging “mary not mary” the resident chemist, lets do this the old fashion way with research via the web and googler.
According to the SDS the product includes:
2.5-10% Sodium Dioctyl Sulfosuccinate
What is that? Googles says:
All-purpose surfactant, wetting agent, and solubilizer used in the drug, cosmetics, and food industries. It has also been used in laxatives and as cerumenolytics. It is usually administered as either the calcium, potassium, or sodium salt.
1-2.5% Glacial Acetic Acid
Glacial acetic acid is the anhydrous (undiluted or free of water) form of acetic acid. Acetic acid is considered an organic compound and has the chemical formula CH3COOH.
A diluted solution of acetic acid is known as vinegar or ethanoic acid or ethylic acid.
.1-1.0% Sodium o-Phenylphenate
antimicrobial agents used as bacteriostats, fungicides, and sanitizers. Both have been used in agriculture to control fungal and bacterial growth on stored crops, such as fruits and vegetables
.1-1.0% Octylphenol Ethoxylate
Octylphenol ethoxylate is a detergent that is commonly used in chemistry laboratories .
So, you are paying for up to 15% stuff and 85 percent water for surfactant, detergent, vinegar, and a highly diluted antimicrobial agent. It doesn’t boost SH.
Let’s say I strip a deck with sodium hydroxide, but for some reason it isn’t effective. I add in some butyl and a surfactant, or maybe some sodium metasilicate. Those chemicals didn’t “boost” the sodium hydroxide, I just added more chems to the mix. Maybe it helps the one chemical work on a paint better, but I also have have less water as a percentage of my mixture.
I’m told I come off as condescending, I’m not trying to be. I am trying to teach you what some of the fine folks on here started telling me, then I did my own due diligence. I choose to believe in god, that is an act of faith, not logic nor reason. My point is, I only believe in what the empirical evidence suggests is the truth. EVERYTHING ELSE IS MARKETING. I’m not a chemist and I didn’t stay at a holiday inn last night, so this opinion is worth everything you paid for it.
