The guys using service beds, how are you mounting the engines? Are you beefing up the structure of the toolbox, and if so how are you doing that? I went and looked at the truck today and might be buying it, before I do I want to make sure I’m not getting into a huge project.
I’m not a welder or a fabricator, although I’m not against paying someone to do fab work.
I’d be taking the racks off, that are bolted on top of the boxes
@Innocentbystander
Do you have to beef them up structurally, or mounting over a door where there is a support already good enough? I know there are variables… it would just be two 13hp engines.
I didn’t do anything but drill 4 holes and bolt them down. My skids are around 400 lbs and I’ve never had any problem. Silicone around the holes and you’ll be good.
