Selling Equipment
I am selling my equipment (see below). Any suggestions on best place to post it. Thanks in advance. (I’m in Queens NY just FYI)
3000 PSI 5.5 GPM Cold Pressure Washer - Honda GX390 - Belt Drive Comet Pump - Electric Start : PSI BK5530HC11235
Titan 4818S Manual 18 in. Aluminum Pressure Washer Hose Reel. (2 PIECES)
Telescoping Wand: 24 ft Long, 4,000 psi Max. Pressure, 8 gpm Max. Flow, 1/4 in Q.C.
Whisper Wash Classic 19"
BE 1600WAW 16" 4000PSI WHIRL-A-WAY SURFACE CLEANER (85.403.003)
Xero Screen Cleaner (serial #2457)
XERO Pro Basic Carbon Fiber Water Fed Pole (50 ft)
Are you upgrading or changing careers?
Check your DM.
Changing careers.
