What thread sealant should I use for leaks on the hose reel? For the hand crank and other connections. Used thread tape which I’m aware probably is a no no.
Thread tape is fine. On big plastic fittings try pipe dope.
3 wraps of tape with blue dope on top for any metal, tapered fittings. Dope only (no tape) if there’s a plastic female, but be careful; the dope acts as a lubricant and it’s easy to split the female thinking the connection isn’t tight enough.
I’ve never doped tef tape but I always had to run a extra wrap (5) on the China tef tape I used. Ebay 5 for .99 shipped man that stuff was thin, it was almost transparent lol took me 6 years to eat through my supply of it.
I didn’t think the brand of Teflon tape could make that much difference and never had an issue until recently. Adding a swivel to my gun, I could not get it stop leaking due to the cheap quick connect fitting I had. Even doing a lot of extra wraps and dope it still leaked. Before buying a new fitting, I figured I’d try the Blue Monster tape and dope. Been using it for a few weeks not and not a drop coming out. You get what you pay for with tape and dope, so buy the Blue Monster stuff and you won’t have any leaks.
Thanks the regular tape wasn’t cutting it even with the extra wraps like you were saying I’ll give it a try!
I second blue monster. It’s the only tape/ dope I use. father in law. Master plumber only uses that tape as well
There’s a constant thread in the plumbing forums that goes back and forth (like our rinse/don’t rinse one) about this. Some people do it, some don’t.
I do it because it’s what I was taught as an apprentice plumber and it just kinda stuck with me. Who knows if there’s any actually benefit versus just an extra wrap or two.
And I hear ya about that cheap tape lol. I’ve had some that near about floats off the spool
On high pressure metal fittings I now use blue threadlocker. Quick and easy to apply and it’ll never leak. Once you try it you’ll never go back. BCE who makes Hydromax use it on their fittings. I came across some threadlocker that is in a container like a glue stick. Just turn your fitting in it and you’re good to go.
Do you have a link for that? Sounds highly practical.
$20 bucks for 19 grams !!! Golly !!
I can get 19 rolls of decent teff tape for that.
Y’all to rich for my blood, high falutin fancy SH washers !
That tube will last you longer than 19 rolls of teflon tape. I’ll send you a tube. Once you try it you’ll never go back to crappy teflon tape.
I guess a few people bought it because it’s $26 bucks now. I used to hardly ever want to share links of my finds because of companies jacking their price up when they sell a few.
I’ve wanted to try Loctite PST 561 pipe thread sealant with PTFE but never got around to it.
Stuff works like a charm thread tape is now trash to me lol
