Sealer ‘traction aid’
For those that seal concrete, I’m thinking about adding a traction aid which runs about $30. The last top coat job I did came out fantastic but it turns into an ice rink when wet, and I’m not trying to cause an elderly person to break a hip.
The White Cap supplier near me couldn’t tell me whether it would plug up my 1gpm sprayer nozzle, hoping someone on here can verify.
Maybe if you used the finer grit it wouldn’t plug it up but I’m guessing it still would. The challenge is that you have to constantly (and I mean constantly) stir the sealer or the grit all falls to the bottom.
I’ve only ever rolled it when using the grit. You could always do a test run with water and a little grit to see if it comes out just spraying it back into a bucket.
