I have a hot water washer with 4,000psi and 4 gpm… Now I have a commercial job that is going to require removal of rust and oil spots. Any suggestions on what I should use?
Wash Authority
Missouri
Wash Authority
Missouri
EBC and F9 BARC. I can help you with the rust removal restoration part or any concrete restoration for that matter.
I’ll need to know a little more about the concrete, the source of the rust and what it looks like. There are 4 different types of rust stains and then some stains that look like rust but are actually battery acid burn.
If you’d like my help I can be reached at 855-803-1133.
Regards,
Craig
Here’s an example of what you can accomplish with F9 BARC. It’s pretty amazing stuff.
https://plus.google.com/100665270728276805942/posts/Wgb8vf5ZwnV
F9 is the way to go for rust removal.
