When washing a roof that has moss, how do you / do you remove the moss with a push broom or brushes?
Should I just rinse the roof with water after applying chem, and try my best to remove the moss with the water?
If moss comes off after rinsing the chem off of the roof, should it be removed from the gutters?
or should I only do a roof wash with a gutter cleaning included?
how many people on here simply chem the roof and leave?
Blow, spray, leave. Lots of plant protection aswell but that’s all we do to our roofs
I appreciate the response
where do you blow the moss? into the gutters or off of the roof?
We don’t, just blow off leaves. Always blow gutters as a courtesy if it’s easily doable
If the moss is that bad, you can take a stiff broom to remove some before you apply your chem. Remove it from the gutters afterwards if you decide to do so.
