Getting ready to add roof cleaning to my services and wanted to ask whats the best reel to use. Im not getting Bobs Bandit kit just due to the size and space on my trailer. I was thinking about getting this REEL taking the wheels off and bolting to the trailer. In my mind Im thinking that this will hold up better for the SH flowing through it.
Please educate me on this if you have a great idea,tip or a great reel…
The Home Dept reel does not look like it would hold up very long and I’d guess you would be unhappy with it reel (sorry had to) soon. The plastic reels don’t roll up smooth like a metal one. Don’t waste your money. Just my opinion.
Stainless steel is the way to go. I have had mine 3 years and the only thing I’ve had to replace are the gaskets. Like JC said shuffle things around and make space for a Fatboy bandit.
Alex, I used that Home Depot reel for a year or two. I put quick connects on my hose to connect to the pump and gun. I only used the reel to “store” the hose, I did not run the mix through the guts. It was still working good when I upgraded it.
Thanks i just went on Amazon and found 1/2in barbed banjo Cam and grooves . Hopefully they work i have all 1/2 ID hose . This kit is great but had to get alot of my own extra stuff . As well
Cam locks work pretty good just try and keep any side load off the connection or they can leak . Also SH will eat the rubber seal so remember to keep an eye on them. And order extras
