Roof cleaning - ARMA - what is it?
The Asphalt Roofing Manufacturers Association is often referred to as ARMA.
They represent many different makers of shingles and as industry spokespeople, they publish guidelines for the use and care of their products. One of those guidelines (technical bulletins as they call them) refers to the lightening of stains on asphalt shingles. The process that they recommend does use TSP but they also are assuming the use of store bought bleach. There are many roof cleaners who do not use TSP in their mix.
The Arma method basically uses a detergent solution to clean with a notable and total lack of any pressure anywhere in the process.
And then there are the other guys. Those that would use pressure instead often tout the ARMA method as dangerous and destructive. Sure, because then they can’t sell you a pressure washer and surface cleaner.
Roof cleaning can be a rewarding and profitable business but please, do your homework first and learn the perils, pitfalls and potential death that awaits you if things go wrong.
Attached please find a jpeg of the most recent ARMA Algae Bulletin. It is the basis for the Hagerstown Maryland roof stain removal process that we use.
I’ve read that a number of times. Thanks for posting, Tim.
I have it hyperlinked from my “roof” page on my site…
Sent from my iPad using Pressure Washing Resource mobile app
Thanks Tim for posting that article for the guys to know about, we give that article and this one written by Angie Hicks of Angie’s List on a laminated FULL PAGE front and back to the perspective homeowner prior to submitting them a proposal for Non Pressure Roof Cleaning.
This small extra step of informing the perspective homeowner of this service has increased our revenue beyond belief. It’s a small investment to make, big returns to yield.
Living Smart: Roof Cleaning[COLOR=#000000][FONT=sans-serif]by Angie Hicks, Founder of Angie’s List
[/FONT][/COLOR]
You may have the most attractive landscaping, beautiful windows and charming mailbox, but black streaks running down your roof can ruin your home’s curb appeal.
What causes those dark marks, and what can be done to eradicate them?
Roof experts who are highly rated by members of Angie’s List say the source is an algae called Gloeocapsa magma. And depending on the age and condition of your roof, cleaning may be the most cost-effective solution, since it’s about 5 to 10 percent of the price of a roof replacement, which can be as much as $10,000.
Algae-caused marking isn’t preventable but can be removed, though not always permanently. The algae survive through photosynthesis and by feeding on limestone filler used in asphalt shingles.
Black marks became a problem about 20 years ago, when manufacturers began adding limestone granules to add weight to material used to coat shingles.
Roof experts tell our researchers that though other components are being added to shingles to hinder algae growth, they still get calls to deal with black marks on relatively new roofs. They say that while shingle manufacturers offer products treated with copper or zinc to inhibit algae growth, their effect wears down over time.
Most black streaks form on the northern slopes of roofs, where it’s darker and wetter – ideal for algae growth. Areas of the country with low humidity have fewer instances of roof streaks, while the problem is relatively common in the Southeast, where it’s more humid and warm. The algae appear blue-green when the organisms form an outer coating to protect themselves from ultraviolet rays. Algae turn black when it decays.
While the dark streaks are unsightly, experts tell our team that the greatest danger to the roof is from moisture retention or root damage that algae and other life forms can cause. Also, algae and fungus can grow together to form lichen, the roots of which can wrap around and feed on the granules covering the shingles. Once established, lichen is not easily removed. Even if it dries out, it can come back to life with the next rain. Scrubbing or power washing lichen will only cause more damage.
Before determining whether having your roof cleaned is the right option, be sure you have a sense of your roof’s age and condition, and compare costs accordingly. A cleaning can cost around $200 to $1,500, depending on the size of the roof, its pitch and height.
When hiring a company to clean your roof, consider this advice, gathered by our research team, which talked to multiple highly rated roofing experts:
-Make sure the cleaners don’t use high-pressure washing systems, which can remove granules coating shingles, and lower their life expectancy.
-Ask what kind of cleaning solution the company uses. One highly rated roofing expert said he uses a chlorine-based chemical wash with a soaping agent. Also, make sure the company has a plan for preventing possible damage to your home or landscaping from runoff. That same roofing expert said he has one worker apply the cleaner while another saturates nearby areas with water to prevent damage.
-Ask how long the cleaning method should keep the roof algae-free. A range of two to five years is normal.
As with hiring any contractor, ask family and friends for references or check online consumer reviews from a trusted source, get several bids, seek and contact references, and confirm liability and workers’ compensation insurance.
And then, prepare to once again enjoy how your home looks without those dark ugly roof streaks.
I meant to give my resources as to where I obtained that article from, eClean Magazine.
Great information online! you will have to copy and paste that link because I only have two post and it takes more than 5 to post pictures and hyperlinks.
[MENTION=2426]mrwindow1[/MENTION]
That’s a great idea giving customers the laminated pages to read, should save some time explaining verbally, and
gives customer a chance to sit down and read at his/her own relaxed pace.
