Repairs
How many of you guys fix your own pumps! Had one go bad today just got to order parts now
I fix my own pumps plus I have some spares for emergency change outs. I can’t afford to be shut down over something like a pump not working correctly.
Are the pumps easy to repair? Haven’t found a lot of info on them. I had one go out on 17 gpm machine had to bit the bullet and buy another.
Sent from my SM-N910P using Pressure Washing Resource mobile app
If you know what your doing and have access to parts, I would assume not to hard. I have depended on one area distributor/mechanic/PW whiz for the past 13 years for virtually everything, chemicals, equipment, stain, including anything more than simple repair.
Figure my time is worth more trying to run a business than trying to fix stuff without experience or mixing my own chems. Good, competent suppliers are more than worth it.
