Customer has a backyard patio with poor drainage. I’m not looking to get some permanent, expensive setup, could I just get a used sump pump and drain the dirty water out? I believe there’s an electrical outlet nearby.
I use mine more then I ever thought I would. In one instance I attached 30’ of pool vacuum hose with duct tape. It works great. I think I learned about it in @Racer flatwork video
