What’s up guys, I haven’t had very good success using the turbo nozzle on paint like this in the past. Is there any kind of chemical that I can lay on the paint and then maybe surface clean it off?
Yes, there are paint removing chemicals. A surface cleaner has lower pressure than a turbo, if you set up your tips correctly. Did you try heat? Did you try any citrus based or Hydroxide based c leaners? Did you allow sufficient dwell time? All these factors matter. A lot of the newer people on the forum think spray on spray off, that isn’t how many things work.
