Are you guys getting near full pressure you calibrated for, after shutting it off.
Red, I am not understanding your question. If you have a three way remote that allows you to pull water when you aren’t pulling soap, you won’t see any reduction in flow , if that is your question.
gotcha, that’s what i need. 3 wsy remote
BSP 1/2''-1'' DC12/24V 3-Way SS Motorized Ball Valve CR3-01 with Manual Override | eBay is this what you are looking for? Now you will have to get a remote control to add to this for it to work.
Probably needs a 1/4" one since it’s for a downstream injector… about $40 on amazon/etc.
Just an FYI, I had zero luck with those blue valves, kept burning out. I spent the $$ and got a TeeJet, but I see they are considerably more expensive now.
This is the one I use, no chemicals go thru the actuating ball valve, just water. No issues….love it, going on 3rd season with it.
You have 1 with the chemical injector bypass? So, when it’s closed it goes around the ball valve and draws DS chemical, but when it opens the water-only goes straight through the ball valve?
Correct……you get more flow when in the rinse mode. Absolutely love it….
