Decided to spray my trailer floor on my own with Raptor liner. This stuff is very easy to use and you cant really mess it up when spraying if your not a good painter. Steps as followed.
-Marked 2ft up the walls in pencil all the way around.
-Ran a clean tape line with Frog Tape at the 2 ft mark.
-Masked off all metal flashing. “You can line the flashing if you prime it I choose not to.”
-Ran 12 inch paper up from the clean tape line I ran.
-Double and Triple checked everything had a good seal on the tap and masked off some exterior parts of the trailer for over spray purposes since this was happening outside.
-Mixed 250ml of hardener to a bottle of spray, directions comes included in the kit and went to town at 55psi.
Over all impression is its easy as pie to use and looks great time will tell how well it hold up to everything.
