Sounds like all the steps for a fence. I use caustic soda though.
Im gonna give it a shot.
What did you charge for a playhouse that size?
That turned out great! Nice job!
This was just a practice one for me, so I canât help you with the pricing. Iâll give you a few things to think about, though:
Do you need a ladder? I had to get up on an A-frame to do get the roof to come out right.
Do you have to rinse the oxalic? Itâs not an issue on the wood, but it leaves a white residue on the plastic parts.
Are you washing the inside and the outside? If you wash the inside, you will get very wet.
Do you want to use a different approach for the wood and the plastic? You canât really see it in the picture, but the tunnel slide had tiger stripes like a gutter. I donât know if the caustic soda would clean that.
Whatâs going to happen to any stain that is still on there? Look at the shutters in my pictures.
5 minutes rubbing ATF on the plastic if you really want to take it to the next level. Left window is with ATF. Right window is without.
I wasnât going to ask about pricing but wondering how long it took. I was just curious if itâs worth the time and effort to upsell them or pretty much shy away from them. Some of those swing sets arenât cheap so some are probably okay with paying a decent price.
Jury is still out.
I donât recommend the percarbonate. 30 minute dwell time and I still had to get up on the ladder to hit it all over with pressure. I see no advantage. Itâs not strong enough. And this swing set wasnât even that dirty.
If I was going to do it again, Iâd try SH. I think that would work faster and do a better job on the plastic parts. Maybe I wouldnât even need the ladder. I could just rinse it from the ground. Plus I wouldnât have to mix up another chem.
The percarbonate is a spray it and leave thing, with time it can clean, rain will help, but itâs probably better suited for roofs
Absolutely not a spray and leave thing
The advantage is itâs more environmentally safe
Iâm talking about for wood. The ph of Sodium Perc is about 10.5 versus about 12.5 for bleach so itâs fine to leave on a roof.
