I’m planning on introducing pressure washing into my window cleaning business next spring and I am just practicing on a few clients house for a small price before winter. I recently ordered my stuff from pressure tek and I’ve been asking them most of my dumb questions but I haven’t heard back from them in a few days.
My supplies right now are:
5.5 2500 GX390 electric start
Jrod downstream kit
down stream inj. with bypass kit
WW classic
35 g buffer
1 hose reel with 150’ pressure hose
1 hose reel 100’ supply hose
100’ extra supply hose, 100’ extra pressure hose
A few pallets which I will mount equipment in the bed of my truck
My questions are:
With the electric start, do I have to put the battery case back on after I wire it? (because I’m not sure how it would fit with the wires coming out)
Should I always keep the throttle all the way up even when starting the machine? Or are there any times when it shouldn’t be all the way up?
There should be a gap or two under the lid of the battery case for the wires to fit through.
I start my machine at 2/3 throttle. Probably more a superstition than anything. But IIRC I’ve had it stall shortly after starting if I was too quick to go full throttle or took off the choke too soon.
I drop to minimum throttle if I’ve run the buffer tank completely empty and need to prime the pump.
I see marinegrunt has beat me to the punch.
I use tape on pretty much everything. I just don’t like sticky stuff. Very rarely get leaks, and have only ever broken a couple of plastic fittings from over tightening. But using tape on everything is not considered “best practice”
I like using 1” hose on everything, because it should also be sufficient to run 8gpm if/when I decide to upgrade machines. Plus, there’s a number of other parts that use 1” as a standard. For instance, Hudson float valves and full flow 1” manifold supply reels.
I skimmed too fast and was thinking you meant 3/4" for supply so I would definitely listen to Alex and go with at least 1" from buffer to machine. I’m sure 3/4" would be fine but I don’t know if I’d call it plenty like I said above.
I sometimes use teflon tape on plastic. To be honest I just use whatever I happen to have. They both work fine.
