Agreed lol. I’m just gonna go ahead and order that 2305
sorry
Don’t be! Keep after it. I’m at 7 days read time and still on here waaaay too many hours a day.
It definitely has taught me a lot
@marinegrunt @TexasPressureWashing
Anymore keywords to research?
Have you hit fallout, booster pump, and ribs?
Start looking into the threads about pressure washers too. 4GPM, 5.5GPM, and 8GPM. Also 12V roof systems. Look at the trailer build threads too. Then look into the chemicals used for different situations. Learn to read the nozzle chart and the chemical mix chart etc.
Thanks for the suggestions
house wash mix
roof wash mix
deck cleaning
rust stain
buffer tank
degreaser
acid
Engine won’t start
Dead grass
Oxidisation
Pre treat
Post treat
Friction loss
Nozzle sizes
Maintenance
HP to PSI calculation
Concrete striping
Degreaser
Hot water
Hose size
Etched aluminium
Water stains
Ladders
Booster pump
12v pump
Diaphragm pump
Hose reels
Siphoning
Gear drive
Engineering degree for belt drive pulley removal
Direct drive
Ball valve
Quick connects
Pressure loss
My fingers are sore but I think you get the idea. Each of these will have about 20 subsections attached to them read those as well. And remind @marinegrunt @TexasPressureWashing @Jake_Lambert every single day if they’ve sent out your goodies
And dont forget the most important and popular thread of all for him to read and soak in is ?
Truck washing, Soaps ,tips and tricks !!
Don’t forget a hall monitor badge for thread derailments.
Thanks for the help
@Jake_Lambert
@marinegrunt
HALF WAY THERE:grinning:
Oh you’ll get there. Now you won’t get hourly updates so you need to keep grinding. Then once you reach 2 days don’t stop.
Way to go! Did I forget to mention that you’ll have to pass a quiz once you hit the 2 day mark? I hope you’re taking notes!
Haha I am
@Field another thing is definitely use the bookmark feature. You can bookmark threads or individual posts in the thread. I have over 200 bookmarks and I add more daily. Also be prepared to go back and read some things again later as you understand more you might learn something from a post you’ve read before because your knowledge is more complete.
Oh thanks that will be a lot better than screenshots like I have been doing
It definitely is! Have you started thinking about how you’d like to set everything up yet, whether it’ll be on a small trailer or if you’ll have to unload everything at each job? Bypass tank so you don’t have to use a weep gun, etc?
