I am experimenting on my concrete again. I do this because I won’t work on someone else’s place until I can make my own drive clean to my satisfaction.
I ran my surface cleaner (whisper wash classic) on the driveway before with just water, no chems, no pre or post treat, just to make sure everything was working and not leaking.
Today, I pre wet the concrete, applied SH at about 2%, waited a bit, ran surface cleaner. While running the surface cleaner perpendicular to line of sight (TY racer) I noticed no matter how slow I went, there seemed to be a line of dirt left behind. I was pushing forward, pulled it sideways, went backwards, same thing. So I went over a decent section, overlapping about 9’ inches, still happened. I went and throttled down the machine a hair just to see, still occurring. In some spots the machine seemed to float easily over the concrete, and in other spots it seemed to stop.
So I finished the drive, but didn’t like how the one section was turning out, it looked blackish (where the cars park at). I then went and got a degreaser, watered it down, applied, then ran the surface cleaner over it again. I then went and rinsed the whole drive down and post treated with about a 2-3% mix in a pump up (what a PITA that was). I am waiting until tomorrow morning to take a pic so that the post treating has time to work.
THe section that looked darker was poured a year before the last section, I can still see the broom finish in the concrete, but am concerned that th esurface cleaner might have removed some of the cream. THe only other thing I can think of is that the asphalt (which is next to the concrete) was sealed last year and maybe there was some runoff over the winter darkeneing the concrete. I doubt it though, because this is the second time I sealed that asphalt with the same sealer, and it didn’t do it before.
Any thoughts or feedback would be appreciated.
8gpm unit with only cold water used. 12.5 SH used, but diluted with water.
Edit: side note - the non marking hose I got from BCE leaves blue marks all over black asphalt.
