Do you guy’s run manual throttles or those self governed throttles?
I just picked up a new hydro tek and I don’t like the fact that it has a self governed throttle, I like being able to warm up my machine on idle for a couple minutes also love to cool down my heater with my machine running water at idle… not a huge fan of my machine going 0-100 while cold either
At the end of the job I open my ball valve and I let the water run out til my heater is cool to the touch, it helps me because I also drain my buffer before the next job… I don’t see how this wouldn’t work at cooling the coil down
Ya’ll are doing the same thing, just different techniques. Lol. I also agree with the 0 to 100 with a cold motor ,but I have no advice, I have an older honda with a throttle
Opening the ball valve is the same as being on the trigger…it causes water to be circulated through the coil. As @Hotshot said…it is the same thing, just a different technique.
Same here I have an gx i390 and I’m not a fan of the no warm up period either. Can’t be good but I like how it drops rpm when I’m off the trigger for a bit.
Then I wonder if its getting enough air from the fan?
Better break out the infrared temp gun and check it out .
Honda is the king of small engines, I don’t believe they would design a system the hurt the engine. These engines are designed to run @ full throttle, I got faith in RED!
Gonna walk back what I said a little bit. Just don’t use “gay” as an insult please. It’s 2019 and I don’t want to have to deal with that ■■■■ on a forum of professionals.
I sincerely hope you weren’t lumping me into that category. I don’t feel the need to divulge my background but let’s just say I’m down with the gays. And, no, I’m not gay. Sorry guys…
