PWRA members, now you can get 10% off of Float software! Float is simple cash flow management, forecasting and budgeting software.
Important points:
•Good new if you use Xero discount offered by PWRA: Float is fully integrated with Xero and FreeAgent. When you update your accounts, your forecast in Float changes, giving you an accurate projection of your future business.
•Float provides simple data entry and reporting. You can set up spending budgets for your business, track where you’re at right now, and forecast future spending easily.
•Play around with the numbers to understand different financial scenarios. Use clever tools to get a good understanding of patterns, seasonality and potential upcoming issues.
•Share with your team: Everything is online, so you can access it anywhere, anytime - and your team can collaborate on the numbers. Keep everyone in the loop so they know where you are.
There is a 30 day free trial if you want to try it out, no credit card needed: Float
Email jessica@pressurewashingresource.com if you want the discount code to get your 10% off!
Not a member yet? What are you waiting for? Join for $199! Click here to join the PWRA!
