Pulsation control
Good evening,
Thank you to every one that answered and helped in my last question.
I am one step closer to building my jetter.
I have one last issue… I am trying to create a pulsation control, I’d like to control it from the back of my trailer.
And the pumps and engines are about 10 foot away.
I have seen a manufacturer use a needle valve at the back, and the. Connect a 1/4 check into the middle lower port.
Does anyone have any knowledge on how this might create pulsation? I’ve researched for weeks and chat GBT is just as useless.
All help is greatly appreciated.
From what I have seen, using a needle valve with a check valve can help create controlled pressure fluctuations that result in pulsation. You might also want to look into a dedicated pulsation valve setup, as it can be more consistent and easier to adjust.
Thank you for your reply, I assume the check valve would direct away from the pumps and the other end of the needle valve would just overflow to the tank?
