Mine broke once 3 years ago…
Replaced because it looks good
I just replaced mine with paracord, about 10 times stronger.
The cobra cord seems a lot stronger than paracord
The standard cord they use is rated about 90 strength, so pretty much anything going to be stronger. The paracord I used was 550 and I know they make an 1100. What’s your cobra cord? Though hopefully I never have to replace again, lol.
Snowmobile Pull Starter Cord. Guaranteed for Life! https://www.amazon.com/dp/B00BNJEV7A/ref=cm_sw_r_cp_apa_i_mSEfBbDC3ND39
Bummer…
You likely just need a little more than an arms length. I doubt you pull 3ft of cord. Ill have to go measure.
They have a 91" model. I just ordered the wrong one. My concern is the number of wraps needed around the recoil.
Check this out at Amazon.com
Cobra Pull Cord Handle - Gokart, Lawnmower, Chainsaw, Boat motor, Generator (yellow) https://www.amazon.com/dp/B07BQPYP1B/ref=cm_sw_r_other_apa_tmB6BbREJXEHH
They are 88" in length, you can cut it, just like i did to make it fit just right
I saw that one. I have it on my Amazon list.
