Proportioner Setup
Gang,
When putting together this proportioner system, do I need to use a drop stick to pull water or is gravity feeding from the bottom okay? I’m putting together this rig and about to do my tank setup. It had me thinking that if I bottom feed, gravity might force too much water and not allowing proper proportioning ratios if that makes sense. Do people that use proportioners always use drop stick and those that don’t use proportioners bottom feed? Or am I over thinking this thing.
Also last question. For the return bypass, I’m assuming you want it to have a drop stick or at least be long enough so it goes into the existing water to not cause bubbles/air when the water falls back into the tank.
Thanks guys
For the return, I just have mine going into the top of the tote through the reinforced vinyl tubing. It makes happy splashing sounds that sooth the ears and makes my tote look like sparkling water inside with the hose bib running into it to. I just like to stand there and look at it while mindlessly spraying SH and water wherever. :laughing:
Can’t help you with the proportioner. Have a good one.
