When you talk about switching chem, does that mean you pull the inline injector from one chemical and put it in the other?
5AlarmMobilePW
5AlarmMobilePW
Yes.
Get a three way switch mounted to your gun!! Run two lines with your pressure hose. One from step 1 and another from step 2. A little heavier to use but the benefits are worth it. No walking back to the rig between chems!
What’s your favorite 1 step chem and where do you get it
5AlarmMobilePW
I use a three way valve to switch between chem 1 and 2. Greenwater what chem are you using, mine are making the aluminum white. Not really liking that.
PM me
Just wanted to thank all you who posted on this thread. Greenwater especially, thanks for being patient with me and going out of your way to school me. I have ordered all the parts I need from Pressure Tek and am stoked about getting it set up. I’ll post some pics once I incorporate the new set up. Thanks guys!!
Aaron Easter
5AlarmMobilePW
Oklahoma City Metro
Fleet Washing
Hi green water, my name is james. I’ve been fleet washing heavily for the last 4 ya and use heavy caustic cleaners and brush everything. I am labor heavy and am interested in moving to two stepping. What if at all advise can you give me in regards to “how to”, recommended 2 step chemicals to use, cost per vehicle to two step, etc. Any help would be greatly appreciated.
Hello sir, where di you buy the 2 step chemicals? Do you have to regulate the ph of your water?
