For those of you with Pressure washers, how many of you have had trouble with your equipment? If your like me, it never breaks down at the shop or near my repair guy or when I can call someone…its always at night on the weekend at 2am! HERE IS THE CLASS FOR YOU! Russ Johnson from SouthSide Equipment is putting on a paid 4 hour course on Repair and Maintenance in Huntsville, AL AFTER the Workshop on Sunday November 11th. The cost for this class is $149.00 and I promise will save you money! You do not have to attend the Workshop to come and this class is open to everyone. Here is what will be covered:
Hour 1:
Basic trailer / truck set up
Pre-trip the rig
Engine troubleshooting
Why is there gas in my oil?
Charging systems
Ignition
Valve and governor adjustment
Identifying oil leaks
Loss of power - what to look for
Hour 2:
Pump troubleshooting
Rebuilding the pump and what to look for
Unloaders - theory of operation - emergency fixes
Plumbing - to the pump through the gun
Hour 3:
Burner principles of operation
120 volt vs 12 volt pros & cons
Burner controls
Repair and adjustment
Hour 4:
Engine wiring systems
Machine circuitry
Burner wiring
Q & A
There will be a 10 minute break between each segment.
Register here for the class
http://huntsvilleworkshop.com/<wbr>registration/
